harveye
- Sep 7, 2022
- Location
- New Jersey
- Genesis Model Year
- 2023
- Genesis GV60
Over Thanksgiving, I took my first road trip (227 miles each way- NJ to DC suburbs) and have a number of notes and questions to throw into this forum. Charged to 100% the night before (Level 2 home charger). Range showed 247 miles. The outside temperature would be 40-55 degrees for the trip, so assumed there’d be some heater power loss. Set navigation for EA DC charger 127 miles out. After heating the car for a few minutes in the driveway and setting navigation, I noticed I started the trip with 234 miles range. I drove in standard mode using Driver Assist and Smart Cruise most of the way. When I arrived at the EA DC charger, my remaining range should have been (mathematically) 107 miles. It was 66. Not so good. It got worse when I discovered the new EA chargers were not operational yet (still tied and wrapped in plastic) and the one old EA charger was trashed. They showed as operational on the EA site. I called EA and reported my situation. The rep apologized and then confirmed that the next available EA charger on my route south was 46 miles. Range anxiety started creeping in. I drove to the next charger in Econ mode. The 10% SOC message flashed about a mile from the charger. Fortunately, all the chargers were operational and available (one other car). I was able to charge at the 350 charger from 10% to 80% in 25 minutes.
The return trip the next day was completely different with new insights. When we departed, I had 103 miles range and only 56 miles to go to make it to the same charger I had used the day before. When my GPS got lost within 5 miles of the charter amidst new road construction, it was only annoying rather than panicking since I had 50 miles left. When I pulled up to the 8 chargers, I noticed the two chargers marked as 350 were in use, but thinking maybe one charger can be shared, I backed in within range of the second plug. However, looking at the screen, I didn’t know how that would work and I didn’t want to touch the screen and accidentally stop the charge for the BMW currently tied up. So does anyone know if one charger can be shared? If not, why do they have two plugs? When my charging neighbors didn’t have any answers for me either, I just plugged into the adjacent 150 charger. To my surprise, it showed I would get to 80% in 15 minutes, faster speed than yesterday’s 350. When it did get near 80% I did some math and saw that it wouldn’t quite get me home, so I raised the DC limit to 90%. To my next surprise, I saw that the charging speed didn’t slow as I had been told by everything else I’ve been reading for the past 5 months. Less than five minutes later I was at 90% with enough range to just get home if my mile to Kwh rate was similar to the ride down. Just to make sure, since the temperature had rise to near 60 degrees, I turned off heat/AC. The remaining 175 mile ride home was uneventful with Lane Assist and Smart Cruise engaged almost the entire time. Some stretches I drove at 80 mpg and some stretches slowed to red line bumper to bumper crawl. The next surprise was noting that my miles to Kwh rose to 3.5 over the return trip (almost a mile more per Kwh than trip down), so I made it home with over 60 miles to spare.
Some questions:
In this mild cold, was it worth it to put in the DC charger destination in the GV navigation to precondition the battery? Did it precondition the battery? Did the preconditioning sap more energy than the preconditioning was worth?
Running the heater seemed to lower the Kwh rate by half a mile per Kwh. Does that sound right?
Later, when it warmed outside, I actually had the AC running slightly but it didn’t seem to effect miles to Kwh rate. Does that sound right?
Any thoughts on what I could have done better? Any thoughts in general?
Some questions:
