Navigation: Deleting entries in destinations
eaassoc43
Hazlet, NJ
How do I delete an entry made in "destinations", but not made in the address book?
can individual destinations be deleted if they are not in the address book?
Thanks::)
same issue.. would appreicate assistance..thank you in advance..
smiles
On 2013 this is how:
Home menu > Navigation
Navi home > Destination
Previous Destinations > delete
Hope it works for you too
Thanks. BUT...there doesn't appear to be a way of deleting individual entries in destinations. It's a kind of all or nothing. :confused:
Once you hit delete it should bring up a list of previous destinations for you to delete. You can then delete all, or select individual entries/lines. If you select an individual entry it will bring up the map with that location and you should see a selection to delete that specific location on the bottom left of the screen.
Thanks for the help, BUT I still can't delete previous destinations. You indicate that after "Previous Destinations>delete". I don't see how you get to the "delete". Once an address is put in, deleting is no problem, but I can't find a way to delete the "previous destinations".
I appreciate whatever help you can give.:confused:
In my Premium model you just go to the "setup" button to the right of the touchscreen. Yes, it is counter-intuitive.
I have a 2023 G70 advanced - while the 'delete' button is there, it is disabled (grayed out) and I cannot delete any of the previous destinations either. Any help would be appreciated. The car was previously used as a demonstrator (very low mileage), so there is no correlation between my travels and these old destinations.
Have you tried selecting the destinations, then hitting "Delete" ?
I can see the delete option, but it is grayed out - you can't select it. I have a feeling that with the 2023 G70 there are a lot of limitations on the integrated NAV system. Another example is that when you want to set your 'Home' Address, it allows a search but only brings up options that would fall within the POI category (i.e. business names that start with the letters in your street name). All this even tho the NAV tells you that you can search via POI, address or voice (voice doesn't work)
If you select the destination first, then can you delete?
No. It shows all the previous destinations, and if I 'click' on one ... it just reverts back to the map screen to show me the route to get to that destination. The Delete is never enabled.
Hi All, I don't know if this is the issue with your car but what finally fixed mine was that I needed to update the SW in the NAV system. Once I did that, everything worked as it should.
