Navigation- is it possible to have the map fixed and the car rotate?
Aquineas
4th Genesis
Georgetown, TX
I prefer North to always be oriented "North" and would prefer to have the car change its orientation rather than the whole map. I don't think this is possible, but I figured I'd ask just in case...
If it's tech package you're talking about, there's an option where you could change the orientation of the map.
I have mine setup the way you described; North up.
Dan
Sorry for the lack of info. I have a 2010 with Tech Package. I will look at the menus a bit more closely.
Thanks for the info.
Aquineas,
1) Press the MapGuide from the DIS area
2) Then press the round knob of the DIS
3) The Map Options menu will appear on the right side of the NAV screen
4) You then select North Up view (instead of Heading up which I think you currently have as default).
Regards, ld_gen
I have a touch screen, not the tech package. Is it possible for me to set north to the top? 2011 3.8
On the Touchscreen Nav...Touch the compass to toggle the view between North UP and Heading Up
Richard
