New DRL lighting replacements
surprisinguy
NC
Had the problem with the DRL lights, one brighter than the other. I assume that someone had replaced one of them in the past. Had to remove the airbox on the left side - whoever did that in the past cross threaded one of the bolts so that was a bugger to get out. BUT knowing I had to probably cross wire the plug on the left I knew it had to come out. So ended up having to pull the pins and swap them on BOTH wiring harnesses as neither one of the lights would come on. After that was accomplished the Pilot LEDs worked fine. Had to reset the CELight because of the air box but after a few quick flashes on the turn signals the car learned the LEDs and they look great.
Getting my Storm Springs installed on Tuesday!
