Niche Misano M117
kimmy77_02
I was wondering if any of you guys have the Niche Misano M117 rims on your 2nd Gen Genesis ... I ordered a set 20x9 +35 5x114.3 ... I plan on running Michelin Super Sport K2 255/35R20 ... I don't have any plans on lowering it at this time ... I was wondering if any of you guys have the same set up ... If you do ... Do you have any issues with rubbing or having to roll the fender ... Any help would be great ...
my Velgens are similar in design and color. I am lowered and run 20x9 and 20x10.5 respectively with no rubbing issues. I don't remember my offsets but I think you'll be fine.
great wheels Huddleson
gorgeous...but there is no way those struts are holding up with thosw lowering springs.
"No way" or "will wear faster"?
The answer might surprise you,but probably not the rest of us.
Update ...
So I finally received the rims ... They look good but not good as Huddleston ... Have a issue ... So there are two holes for valve stem ... One smack dead center of the rim and the other in the back of the rim ... I can only mount the TMPS sensor on the back and will have to plug the hole in the center ... I can't put a valve stem there because it will hit the brake calipers ... Did anyone else have issue like this ... Any recommendation to plug the hole ...
Thanks in advance ...
