No sound from Route Guidance
shagnat
Route guidance will not talk. I have a speaker cone with an X through it next to the bluetooth icon which is located at the bottom of my screen. Yet I have check every setting I can find and I have volume everywhere except through route guidance.
I eventually had to do a factory reset which of course lost all my saved address but at least it talks.. I checked the setting about "guidance volume" and it was on the higher side but NO voice at all no matter what.
So, what was wrong that the speaker icon with an X through it located next to the blue-tooth icon?
After the factory reset all was fine, just had to re-enter all the saved addresses.
Please help in case I run into this again? (yes I had turned the car off and back on)
--David
--David
Sounds like you had "muted" the guidance...
The only place I knew to check the volume on "route guidance" was in the settings and the volume was in the higher end of the volume scale.
Where is the "mute" icon/button for route guidance? I was not able to locate anything like that.
Had this happen to me years ago with my Genesis. There is a voice command to unmute the mute but I don't remember what it is. You can probably do a search to find it because I know this subject has come up before . I think I have posted about it at least twice.
Push the DIS knob. Turn voice off or on.
Here's the voice command, "Guidance Voice on".
