Now in Korean! Vehicle ahead has moved.
sethm1
2024 G70 2.5T - United States.
Have had the car since January and the vehicle ahead has moved message on the instrument panel has been in English until today. I have checked the settings they are set for English. What happened and what’s the fix? As far as I can tell no other warning or message in a different screen. Oh and guessing it’s Korean as does not look like Chinese. Uggh.
헤드 유닛을 재설정해 보세요.
Yes, that.
How do I get it back to English?
So - start car in Accessory mode - not with engine on.
Then insert pin in hole next to radio vol knob.
Or
Hold setup and map button till Genesis emblem shows on screen?
Goolgle, you tube and digital owners manual (which has nothing on the topic) not helpful.
Well.. I guess it’s time for you to learn Korean!
See if you can use Google Translate with your phone (camera reads Korean and you get the English translation).
And I wish that feature could be retrofitted to the pre refresh G70’s. All the hardware is there, just a little bit of software code.
The insert pin in hole next to radio vol knob did the trick
기쁩니다. 재부팅하면 많은 문제가 해결됩니다.
gippeubnida. jaebutinghamyeon manh-eun munjega haegyeoldoebnida.
