Oil leak near transmission / rear main seal
Van_Nik_75
SUPPORTING MEMBER
137
128
43
Vancouver, BC
Yesterday I noticed an oil leak where the transmission meets the engine block. Judging from the location it could be the rear main seal. There are some corresponding oil stains on the top of the plastic shield. I plan to make an appointment tomorrow to have it looked at. My car has just over 25,000 KMs (about 16,000 miles) so a rear main seal failure now would be very unusual.
Husky
844
93
That would be unusually soon. Let us know what they find. (Also, being the low point, sometimes other leaks will appear to be there, but actually come from somewhere else above.)
Van_Nik_75
SUPPORTING MEMBER
137
128
43
Vancouver, BC
Toddasaurus
REEEEEEEEEEEEEEEE!!!!!
3,280
4,383
Dang.... Let us know what the dealer says. Maybe it's that transmission oil pump seal like @Draco-REX has seen. Makes me scared to look under mine on this upcoming oil change.
Van_Nik_75
SUPPORTING MEMBER
137
128
43
Vancouver, BC
One of the byproducts of having the large plastic shields under modern cars is that oil leaks can be hidden for a long time as it will collect on the top side of the shield and usually not leave a telltale spot on your garage floor. I’ve always liked getting underneath my cars and shining a flashlight in various places.
Toddasaurus
3,280
4,383
I do the same. I consider a good inspection to specifically look for leaks underneath as part of doing an oil change. Just ordered my oil and filter, will be changing it either next week or the week after. I've got my fingers crossed I don't have the same problem as you. The last time I was under my car everything looked clean and dry, but that was a number of months ago.
Draco-REX
186
43
Ohio
If you do have the leak, this is exactly something the drivetrain warranty is there for. Unless you guys have been driving an insane number of miles, I don't see there being any problem having this covered.
Kraig Wilkinson
SUPPORTING MEMBER
1,416
502
New Jersey now live in South Dakota
Yeah that really sucks..
Van_Nik_75
SUPPORTING MEMBER
137
128
43
Vancouver, BC
Update on the oil leak on my G70. It's been in the shop for several days now. I was just notified today that they are replacing the rear main seal. I likely won't be getting my car back until Friday at the earliest.
Toddasaurus
3,280
4,383
My G70 has been in the shop for several days. I was just notified that they are replacing the rear main seal. I likely won't be getting my car back until Friday at the earliest.
Thanks for the update. Sounds like this is something every G70 and Stinger owner needs to keep an eye on.
tarhoosier
749
93
Charlotte
This thread and others makes me think of how (relatively) few true mechanical failures our cars have endured. Removing the interior issues, paint, electronics and so on and thinking just of the engine/transmission/driveshaft/differential/spindle/wheel power source and delivery elements, there have been few issues, of which this is one. The vast majority have been noises, lighting failures and all the rest of the nuisance and occasional serious problems that have happened. I suppose the most serious was two ( I think) owners with the start/stop function failure which was electronic not mechanical since the mechanical parts were replaced with no improvement. So many threads about other issues but the engine/transmission mechanical parts failures have been blessedly few.
This is my impression, as a long time participant. If someone else has a different impression please pile on.
rmod
93
Sorry to hear about that. Hopefully they will check all the other seals while they are in there. In my case, there is still a little seep, so will hold on till it becomes a leak and then take it in. I don't want them to take everything out only to tell me they cannot find the issue and then button everything back in a haphazard manner.
Van_Nik_75
SUPPORTING MEMBER
137
128
43
Vancouver, BC
Update:
I’ve now been driving the loaner G70 for 10 days. I was told that in addition to the rear main seal being replaced, they’re also going to be replacing the oil pan gasket while they’re at it. I guess I can’t fault them for being thorough. When I asked to get an update yesterday, I was sent this photo. It was certainly a view of my engine bay that I’ve never seen.
mrcleeaan
440
63
I'm not even sure how I'd be feeling if I saw my car like that. I'm glad they're taking care of you though.
TinsleyC
1,589
674
Dallas, TX
Woah! Sure hope they know what they're doing.
