oil pressure light on & off at traffic light/idling/low rpm(below 700 or so)
ajwklajdskla1
Member
Georgia
When weather is pretty cold, I'd say below 45 degrees Fahrenheit, after 20 minutes or so of driving, I'm getting oil pressure light on & off at the traffic light/stop sign. then as I accelerate oil pressure light goes off. so I checked oil and it's fine, between Full and Minimum.
after doing some search, there are stinger owners having same issue, only difference is they are usually at 80~90k miles while I only have about 60k miles(2019 3.3t sport).
So I took it to dealership today(temperature is about 60~70 degrees today) and they can't duplicate that & no codes of any sort. they are test driving it again tomorrow first thing in the morning but I doubt it will pop up again since its going to be pretty warm.
I've seen some 2017~18 g80s having similar issue on this forum and YouTube videos, but not g70s.
Anyone having same issue? Based on post from stinger owner, it's not a easy fix so I took it to Dealership.
I will probably pick it up tomorrow and as soon as I see the light again I will just go straight to dealership and show them.
I would check the oil when engine is cold. If level is between full and minimum, add some to bring it to the full level.
Surprised that dealers don’t consider video evidence. Obviously they can’t believe everyone, but they should at least take into consideration. Maybe you could ask them if your passenger manages to get it on video they can start some proper diagnosis.
So what do the Stinger forums say? Is it just an oil pressure sensor or something worse like an oil pump?
I've send them video evidence(I was the only one in the car so I filmed it) and they test drove yesterday and today morning, and they didn't see it so advised to bring back in when its cold again
Stinger forums say its probably oil pressure switch. Some paid almost $3000 USD at dealerships and someone mentioned like $1300 at local mechanic since they were out of warranty.
this video is g80 with 150,000 km or 93,000 miles and having similar issue.
should've explained better. when engine is cold oil level was full, like two dotted line below full mark.
