One Side Plate Light Dim??
Rspected
Hey guys I am wondering if anyone else on here has experienced the same issue and resolved it. Really don't want to get a ticket but so far I've managed to be good. One side of my lights for my license plate is dim but if I hit it a few times it comes back to full brightness. But then goes dim again (probably when hitting a bump in the road...). Its not the bulbs as I swapped them and had the same issue. Have a feeling it has something to do with the wiring and will get expensive to repair. Provided video of my issue
2012 Genesis Sedan R spec 5.0
Check the socket itself to be sure the bulb is making good contact. Check where the wire connects. Be sure the socket has a good ground. Since tapping makes a difference I don't think the problem is down the line but close the the bulb and socket.
Ok I'll take a look tomorrow. I had removed the bulbs and messed with the grounds made sure they were nice and tight and also moved the socket to make a tighter fit but did not make a difference. Also swapped the bulbs and experienced the same issue on the one side only so it isnt the bulb. I will check the wire connection tomorrow. Thanks
Not sure what bulb type, but with the ones that twist in the socket you can clean the contact with a pencil erasor or similar type of tool.
Hey have you found a solution
