over filled
MARTINO442
just did my first oil and filter change. i put in 6.3 qts i am over the fill mark quite a bit. is 6.3 qts correct for 3.8
so unscrew the bolt and let some oil out and recheck
ppp
Check your manual for the correct amount. Did you also replace the filter? (hope so)
2013 is 6.02 quarts, pretty much 6 quarts even.
yes taking some out. manual says 5.49 drain and
refill. i read 6.3 6.0 what is it?thanks
