Overheating
Lilly210
My 2009 Genesis keeps overheating if I don't top ot off with coolant
If you do not have a hose that is leaking, the first thing I would check is the radiator cap. If it has gone bad, when the engine heats up, it will build pressure in the radiator and if the cap is weak, it will allow coolant to blow past and you will lose coolant. Thermostat could be bad. Water Pump could be bad. Hose could be bad. If a hose is weak, it can collapse and cause the engine to overheat. The cap on your coolant reservoir can also cause this.
My water pump was bad, slowly leaking out of the weep hole and gasket surface.
