oxidized/foggy headlights
Youseethefight
Ft. Lauderdale, Florida
Any trick for cleaning the headlights they are a little foggy and its getting worse. mostly on the top of the headlights. Should i pay to have my local detailing car wash do it? I've seen people on youtube use toothpaste and a toothbrush they make it look simple. i just dont want to scratch up my headlights. also i hear the toothpaste trick doesnt last.
For a light oxidation get some PlastX from your local auto supply, Walmart etc. It works like a light rubbing compound and wax for plastic. Squirt some on a pad and clean up the oxidation and buff with a clean cloth.
There are more aggressive solutions but I doubt you need it yet. I noticed you're in FL where the sun is tough on cars; I'm in CA with the same problem and PlastX so far is still working for my 2005 F250 that has been outside it's entire life.
Here's the stuff: http://www.meguiars.com/en/automotive/products/g12310-plastx-clear-plastic-cleaner-polish/
I use Meguiar's Headlight Protectant to help prevent that from happening. It is basically a car wax with lots of UV shield. Obviously, it doesn't restore headlights that are already oxidized (there are other products for that).
Here ya go:
After you have cleaned up some of the oxidation, find some clearcoat protection (Rustoleum)
If that does not work, you may have to use at least 91% iso alcohol (i cannot find 99% - 100% locally). This will help you clean it very well.
Since it is not that bad, use a HIGH grit sandpaper and lots of water (2000grit) in circles then last left to right. Use alcohol again, buff it with the plastic X or other compound wax. Use clean paper towel/microfiber. After that spray with rustoleum. How do I know it works, I have done it to my car already. Looks good as new.
PS: OH PROTECT THE PAINT!!! See my pic
If anyone suggests using bug repellent with DEET, I would say don't. It cleans the lenses fast & easy, but I've read it attacks the plastic & makes it soft.
Tuckerdog1
Tuckerdog1
I wouldn't think that a bug squashed on the front of the car when traveling at 70 MPH is going to be affected by DEET or any other bug repellant.
If you want to try a quick fix, try toothpaste. I used it on my 2005 FX 45 and it went from 40 % to 90 % clarity (approx). I don't think if it damages but it didn't seem like it. I use non-fluoride toothpaste, IDK if that matters but thought i would mention.
I have kept the headlights on my 2011 Genesis waxed since it was new and still no oxidation at all. Weekly maintenance is a must to keep the clear plastics looking good for years.
Check with your dealership. My local dealer replaced mine on my 2015 under warranty. I didn't even ask for it. The service adviser saw the oxidation and offered it to me. She got approval from the Service Manager. It would be worth a try.
