P0068 CEL
Beavis_No_Butthead
New to the G70 family as of a month ago. I have a 2022 3.3t SP AWD with 45k miles. It has recently started throwing a P0068 CEL which is kind of a broad list of possible causes. I took it into a local Genesis dealer and had them take a look but they could not find anything wrong with it and said “Tech found history code after looking through the vehicle. No problem found at the time”. They cleared the code and all was good for about a week. It just came back on yesterday and I am unsure of what could be causing this. The car seems to run and drive just fine which makes me think maybe it’s not a MAF/MAP/TPS issue. I plan to take it back in and have them look over it again but wanted to see if anyone has run into this before or has any suggestions. Any advice appreciated!
P0068 is often a dirty throttle body on these cars. Since it runs fine, it's probably not a failed sensor. The MAP and MAF sensors just need a quick clean with the proper spray. A cheap fix to try before going back to the dealer.
