P0068 Check Engine Light
Beavis_No_Butthead
New to the G70 family as of a month ago. I have a 2022 3.3t SP AWD with 45k miles. It has recently started throwing a P0068 CEL which is kind of a broad list of possible causes. I took it into a local Genesis dealer and had them take a look but they could not find anything wrong with it and said “Tech found history code after looking through the vehicle. No problem found at the time”. They cleared the code and all was good for about a week. It just came back on yesterday and I am unsure of what could be causing this. The car seems to run and drive just fine which makes me think maybe it’s not a MAP/TPS issue. I plan to take it back in and have them look over it again but wanted to see if anyone has run into this before or has any suggestions. Any advice appreciated!
That code means the car's computer sees a disagreement between your throttle position and the air pressure coming into the manifold.
Since it's intermittent, the most common cause is a dirty or failing MAP sensor. It's often not bad enough for the dealer's quick test to find. Pull the MAP sensor and clean it with electrical parts cleaner.
If cleaning it doesn't work, the sensor itself is likely faulty and needs replacement. A sticky throttle body can also cause this, but the MAP sensor is the usual suspect.
