vmi9d3
Check engine light came on last night, P0301 from the reader at Autozone. Here is the definition Google gives me:
What Does Code P0301 Mean? P0301 definition: Cylinder 1 misfire detected. Diagnosis: A misfire can be caused by anything from faulty spark plugs to low engine compression.
Any one else have this issue on a 2018 G80 with 88700 miles?
What causes the P0301 code?
- Faulty spark plug in cylinder 1
- No compression in cylinder 1
- Damage or excessive wear of spark plug wires and/or coils
- Damage or excessive wear of distributor cap (not applicable to all vehicles)
- Damage or excessive wear of rotor button (not applicable to all vehicles)
- Faulty fuel injector
- Clogged EGR valves or tubes
- Burned valves
- Inaccurate ignition timing
- Vacuum leaks
- Low fuel (rare)
- Leaking from head gasket
- Cracked distributor cap
- Faulty camshaft sensor
- Faulty crankshaft sensor
- Faulty mass air flow sensor
- Faulty oxygen sensor
- Faulty throttle position sensor
- Faulty catalytic converter
- Faulty powertrain control module
