Mike734
- Jan 21, 2015
- Location
- Seattle area
- Genesis G90
If you arm the camera to come on it will likely come on and reset at any number of stops you make before you actually pull into a spot. It would be interesting to have it always armed. But the current setup is rather useless IMHO
I think there should be an option for it to auto-arm when under a specific speed so that you can see what is front of you. and option to activate or deactivate that feature would be nice. Just like there is an option to activate or deactivate the back up camera.
+1Well, it's a minor annoyance at the level of the other 2 - gotta turn on the cruise control and auto hold every time I start the damn car. Now it's a routine, get into the car and press 3 buttons - first "turn car on" and the rest two you already know
I agree w/waveman that having it coming on every time the speed is below 9mph would be terribly distracting. I am fine with having to press the button when I need to see a tight parking spot.
Since I only have the 2015 "Signature" version of this car I'm assuming that the Parking switch gives you a top view? I would like this. This seems to be the only car that I have ever owned that I cannot turn in the seat and see behind me to park. My GF's MKX has a beeping chime that gets faster the closer you get to a wall etc. I wish this car had the same - it does chime on cross travel when backing up though.
I'm pretty sure I have everything turned on but I'll double check... so just backing up I should be getting a beeping the closer I get to say a wall? I'm not getting anything like that.As for the beeping, you should be getting a signal as you get close
My problem is that it only comes on once when slowing below 9 mph and then has to be armed again. As I’ve stated, it’s pretty likely you’ll slow at least once before the final maneuver into the spot.
Unless you slow below 9 mph while turning into the parking lot, turning corners looking for a spot, slowing for traffic. You get my point yet?I am not sure what you mean by “once”. i arm it before I am ready to park. Once I slow down it comes on. It stays on until I park.
