Pedal Commander with other upgrades .
badmankwr
I just installed the pedal commander on my 2011 Genesis 4.6 V8 . Already had the PCR ( PERFORMANCE CHIP TUNING ) and COLD AIR INTAKE . Has anyone else added the pedal commander to similar upgrades ? If yes ? What results did you get ? Mine does seem quicker but it seems like for the best result I have to roll on the throttle instead of just flooring it . Could it be the transmission not able to read the input fast enough ?
I have the Sprint Booster, but the same issue. You only have to press the pedal about halfway to gain full throttle. Flooring the pedal usually results in you activating the kick down switch which bogs down the engine especially from a stand-still.
You may also have to switch off your ECS/Traction control for a proper launch since the systems will cut power as well for safety.
