Steve2020
- Nov 22, 2020
- Location
- MS
- Genesis Model Year
- 2014
When I tried to start my car it would do absolutely nothing. With the ignition set to "on" or "acc" everything worked as it should but the SCC, ABS, auto hold and EPB lights stayed on and the EPB would immediately disengage if I tried to set it. If I held the button down to start the car it acted as if the car had been running and you turned the power off, the seat went back and the steering wheel went up. I tried using my torque pro app with bluetooth reader and a wired obd reader but both said they could not connect to the ecu. After checking all fuses having anything to do with the ecu or braking system and finding nothing wrong I started checking all fuses. After finding nothing wrong under the hood I moved to the in dash fuses, it turned out to be the 30A ign fuse.
