plastic insert inside master cylinder 2015 3.8 help, help
charliet1948
loveland, co.
I was going to do a drain and fill on my brake fluid today. Noticed inside the master cylinder there was a reddish plastic insert not allowing me to insert a tube to drain. I was afraid to force the issue and ideas?
I removed the red mesh filter insert on my 2015 5.0 by using pliers to pull on the red insert edges while working it up until the support tabs gives. I ended up deforming the insert edges but it still snaps back into place in the brake fluid reservoir. So be careful since the red plastic is very soft.
I had to remove the insert just to check my brake fluid with a meter due to the mesh filter in the insert that prevent access to the fluid.
