Plastic splash pan under engine
RonJ
NW of Ottawa, ON, Canada
I have a 2013 Genesis sedan with the V6. A couple of the bolts that hold the splash pan under the engine broke off when taking them out and the plastic around the bolt holes is badly broken up. Is it safe to drive the car without the splash pan? I'm somewhat concerned about the low sitting plastic housing for the oil filter, it would be exposed to garbage off the road. Thanks for any input.
The splash pan is not critical, I drove my Passat 100k miles without one. I'd get one from the recyclers and replace it when it's convenient.
Hi Ron,
I just had the same thing happen to mine (same year sedan V6). Just hit 91k miles and in doing an oil change I broke off 6 of the 8 -10mm bolts taking the cover off. With winter coming I wouldn't drive it for too long without the cover as the slush and salt spray will cause rust over time. I am going to attempt to remove some of the broken studs and replace them with new hardware. Moving forward I would recommend to all of you who do DIY oil changes to put a dab of grease on the threads of each one as you put the cover back on. FYI, the official "hardware store" replacement is a M6 x 1mm x 20mm long hex head or flanges hex head bolt. If the holes in your cover are stripped too, you'll need some oversized fender washers.
Later...
Ross
I ditched mine over a year ago just for ease of access when doing oil changes. No issues whatsoever.
