Plz help! Codes: System to lean Idle Bank 1 & 2
nurse85
Genesis Coupe
I just purchased a 2010 Genesis Grand Touring Coup with 3.8L. The guy said it needed a new motor but it runs. It threw 2 codes with the check engine light on. First code, system to lean idle bank 1. Second code, system to lean idle bank 2. There’s no knock or tick. It sounds good. Also the brake pedal is soft. The guy said the Brembo brakes had been bled with no air in the lines. Plz help! I’m not sure where to even start with this car.
