We've been having extremely cold nights for the last few days around here (below -30*C every night) and, yesterday morning, after starting the car just fine and letting it warm up (about 12 minutes), I headed to work and the upper driver-side radiator hose became disconnected while I was going down the highway at 100 km/h.
There's no damage to the hose or radiator but I get the feeling that the coolant mix may be too thin for cold Canadian operation, which may have cause the coolant to freeze inside the radiator while driving at highway speed, which created too much pressure in the cooling lines and led to the hose disconnecting itself.
Thankfully I was able to pull over immediately and shut down the engine before it overheated due to a lack of coolant (there was less than a litre left in the system by the time it got towed to the dealer). The dealer isn't admitting that a lean coolant mix may be the problem, they're saying that the hose must've been connected wrong at the factory (the car only has 3400km on it).
Either way, if you live in a cold climate, make sure you verify that the upper radiator hose, on the driver's side, is well-connected to the radiator and it would be a good idea to have the coolant's concentration tested. It's no fun to be stranded on the highway in -30 weather and waiting 7 hours for a tow truck...
