Pothole damage - undercover replacement - 2015 or 2017?
surprisinguy
NC
Hit a pothole a bit ago and the only damage that I can see is the undercover right behind the right front wheel is damaged - pushed back and bent. It's going to have to be replaced. I have read on here that the 2017 part for this (I have a 2015) allows an oil change without removing the whole cover. My question is, Does this other cover fit perfectly? I think I read that some fastener holes don't line up etc.
I'm probably going to have the dealer do the work, hoping to avoid shipping charges if I bought the part alone. Not sure if they'll even swap it out with it being a different year/part. Thoughts?
I believe carguy has swapped his out. He might be able to help you out with your question. I am also curious about that. I would like to swap my15s cover.
Why not just remove the cover, it only makes the car slightly more aerodynamic
.....the undercover right behind the right front wheel is damaged......I have read on here that the 2017 part for this (I have a 2015) allows an oil change without removing the whole cover. My question is, Does this other cover fit perfectly? I think I read that some fastener holes don't line up etc.
......Thoughts?
Yea, there was some issue with the mounting, but I think it was solvable. There are actually 2 covers. The front one has the access door for the filter. The rear cover has the access door for the drain plug. They are pricey though, about $600 retail/$400 online for the pair.
Here's the thread you need to look at - G80 under-body panels on a 2015 Genesis 5.0 for easier oil changes.
Reasons to have the cover:
Noise isolation
Underbody cleanliness
Slightly more aerodynamic ;)
Really, the first two though.
