power trunk inop
Mike B
st louis county
Hi..I have a 2015 3.8/awd/ultimate 7500 miles. Used the trunk this am. Worked fine.
Went to open it 1 hour later and it would not open either with the button inside, key fob, switch on trunk lid, or the 'rear sensor'. I used the key to unlock the trunk and check 2 fuses in the right rear fender...a 10 amp and a 30 amp. Visually look fine. Manually closed trunk....shut off and restarted car.....tried everything again...no luck either opening or closing. Tried both key fobs too. Also did a search on the forum and could not find anything regarding this issue.
Everything else on the car works fine and battery seems fine.
Before I call dealer , any suggestions.
thanks, Mike
What about the "valet switch" in the glove box?
