My 2015 sedan 3.8 Ultimate is having power trunk closing issues.
The Good: Works fine from inside, will open and close power trunk from dashboard button fine. Will open using remote button, or using smart trunk feature.
However trying to power close when pressing trunk lid button either the power close or power close with lock button on the trunk lid I usually get nothing.
If I very slowly manually close the trunk, simultaneously pressing either close or close lock button, about have way closed the motor kicks in a closes and locks just fine. only tried that a few times, I typically close from inside switch as not to damage the motor.
I read up on the PTL having a position sensor, integrated hall sensor within the drive motor. Curious if that may be the fault. I looked up the part for this assembly 81800-B1000 and it’s pricey so before I experiment, curious if anyone else had a similar issue and knows the fix.
Thanks
Scott
Thanks
Scott
