Power windows problem
evanspears1
Hello,
I have a 2012 genesis sedan 3.8 that’s having some power window problems. The only window that will roll down is my passenger front window and only if you use the switch on that door. I’m trying to determine if it’s the master switch on the door panel, if it’s a wiring problem or something I haven’t thought of. If anyone has any suggestions I’d be glad to try them, and if anyone had a wiring diagram/pin out of the master switch that would be EXTREMELY helpful so I can prove to see if the switch is even getting power. Thanks in advance!!!
Evan
I have a 2012 genesis 3.8 sedan. I've had to replace the window regulator in the left, rear window twice in the past 2 years. When I hit the window switch I could hear the window motor running, but the window wouldn't move. Regulator cost $100, labor $120 at a local shop.
:welcome: Evan to the forum.
Door switch/wiring water intrusion issues are common on our cars. But it's an 11 year old car so really anything can happen. Hope this helps (from the 4.6 manual):
