It's important to understand the difference between "regular" 87 and "premium" 91/93. Mid-grade is an at-the-pump mix of the two. I'm sure the oil companies chose those names to help promote sales.
Many people think higher octane fuel burns cleaner, make sure engine more powerful, or does other miraculous things. Octane slows the detonation rate, which is needed for high compression engines to reduce harmful engine knock (early detonation). However, engines have automatic adjustments to prevent the early detonation, so it's really down to a very small gain in performance which most people won't notice at all.
The most important thing you can do in choosing a fuel is to select a Top Tier fuel. They are proven to have the proper additives. Check it out -
TOP TIER™ Licensed Brands prominently display the TOP TIER™ logo on the pump, pump handle, canopy or in a station window.
www.toptiergas.com
Costco is my go-to, they are Top Tier, and CHEAP.
