problem : no sound when locking/unlocking the car ,,,
From the 2012 (non-DIS) manual located here...
https://skydrive.live.com/?id=1BF62A2A81564279!339&cid=1bf62a2a81564279&
...page 4-15 says:
D030400ABH-EE
Disarmed stage
The system will be disarmed when the
doors are unlocked with the transmitter
(or smart key).
After depressing the unlock button, the
hazard warning lights will blink and the
chime will sound twice to indicate that the
system is disarmed.
After depressing the unlock button, if any
door (or trunk) is not opened within 30
seconds, the system will be rearmed.
HOWEVER, the "armed" section on the previous page does not mention the "chime":
D030100BBH
Armed stage
Park the car and stop the engine. Arm
the system as described below.
1. Remove the ignition key from the ignition
switch or turn off the engine.
2. Make sure that all doors, the engine
hood and trunk lid are closed and
latched.
3. • Lock the doors by depressing the
door lock button on the transmitter
(or smart key).
After completion of the steps above,
the hazard warning lights will blink
once to indicate that the system is
armed.
If any door, trunk lid or engine hood
remains open, the hazard warning
lights won’t operate and theft-alarm
will not arm. After this, if all doors,
trunk lid and engine hood are closed,
the hazard warning lights blink once.
• Lock the doors by pressing the button
in the front outside door handles with
the smart key in your possession.
armed.
will not arm. To arm the system close
all the doors, trunk lid and engine
hood, and try again to lock the doors.
...so it's still not clear.
Tech option DIS system does have an option to set whether you get the single lock beep and double beep for unlock. So the above manual entry citing the chime may be a typo.
2012 DIS manual, page 313:
Door Lock Sound
When the function Door Lock Sound is
switched on, you will hear a signal tone
when locking or unlocking the vehicle using
the key remote.
Weird thing happen to me had no sound but you can hear the doors lock and unlock, so open the hood locate the hood closed sensor (driver side toward the end of the plastic cowl) and look up on the hood if your missing the plunger that depresses the switch then that's why your not getting the audible beeps.
Yes this happened to me, if your missing it hold the hood switch down with ur finger and arm the car it should beep once.
So what did you do to fix it is there a way to order the same part that presses down on it?
There was a TSB way back when for this.
Part# and location here:
