noremacnova
- Mar 14, 2024
- Location
- Northern VA
- Genesis Model Year
- 2024
- Genesis GV60
Hey everyone. I just installed a ProClip mount in the GV60, and although I know the ProClip has been mentioned before in this forum, hopefully some pics will help you visualize better. I also installed an ESR Qi-2 charger with MagSafe attachment and routed the power cable, hiding it as best I could, before connecting to the USB-C below the dash.
Why do all this since the GV60 has a charging pad and decent screens, especially with wireless CarPlay/AA?? First, the car's charging pad is only Qi (original spec) rated, and it's very slow to charge, produces a lot of heat, and often can't keep up with the power demands of CarPlay, much less actually charge the phone. Qi-2 solves much of those issues, and if you wanted to go with a native MagSafe, it would be even better (and more $$). And then second, I want to have use of my phone and be able to see its screen when running an alternate app, etc.
The ProClip mount is $40 (ouch), and you will need more accessories to actually attach and power your phone, but those can be found at lower prices. The ProClip mount is custom designed and sized for attachment to the GV60 center-right vent opening. The mount does not interfere at all with the up/down or left/right motion of the vent control.
Here's what the mount looks like when attached, along with a 17mm ball-mounting plate, before any wires are run. You attach the mount by using the provided plastic spudger tool to open up the trim piece at the top of the vent, and then slightly squeezing the mount, and it expands back tightly. The Proclip uses the standard AMPS pattern, so you can select whatever mount is needed to pair with your charger. For the ESR, I used iBOLT AMPS Adapter Plate. Note that I only used fasteners in the top two AMPS holes, as the lower holes are too close to the ProClip lower arm on the backside to accommodate a nut. This is a small flaw in the ProClip design, but may have been unavoidable due to the sharp angle of the arm. In the end, using only two fasteners at the top is plenty strong. I also did not use the PSA adhesive strips that come pre-installed on the ProClip. Time will tell, but I didn't think they were necessary, and I wanted to be able to reverse and remove it all without any difficulty. So leave the blue pull strips in place.
And here's the back of the ESR Qi-2 charger. Note the use of a small, right-angle USB-C adapter to permit the best routing of the power cable. Instead of the cable going straight down, the adapter routes it backwards.
And here's the ESR attached to the ProClip and ball mount, along with my choice of routing the power cable. Those little black retaining clips are very handy.
And here's the finished look, without the phone in place. Even though you won't mistake it for a factory install, it blends in nicely. If you're really good about routing the power cable, even better! After this pic was taken, I re-routed the cable into the car's USB-C jack. Be careful not to foul the opening and closing of the little secret drawer right above the power panel!
And finally, here's the iPhone attached magnetically. It's an iPhone 12 Pro, but not Max. Those of you who use MagSafe know the connection is pretty strong. As a side benefit (stretching here...), the air vent is in a great position to help cool the charger, as even Qi-2 generates heat.
