Proximity key?
hwks1
Iowa
Can you leave the car running and lock it when the key is away from the vehicle? Just curious......
I don't think it can lock when you're outside the vehicle and it's running.
You are correct in that you cannot lock the car with the proximity key inside. That being said, the car will loudly beep at you if the key is in your pocket and you step out of the car. I'll have to see if the car is in fact lockable while running when the key is outside. Methinks not...
With the car on, you can lock the vehicle using the manual key that is in the fob. It must then be unlocked with the same manual key. This is handy if you need to warm your car in the winter, buy want it locked.
