I pulled the horn fuse in the engine bay fuse box, and upon reinstalling it found that:
1. my voice commands had functionally gone off line, as if the mic was muted, even though after pressing the voice button on the wheel it would prompt 'ring'.... and then say 'pardon' and take me to the nav voice commands screen, but still unresponsive to voice commands
2. the system screen said that the SDS was 'in process'.. for over 1 hour
After shutting down the car, and restarting, the SDS message was gone, but the voice commands did not come back right away. It did eventually after about 15 minutes. I could find no setting which effected it (to start up again).
To test the fuse pull issue with certainty I yanked the horn fuse again today, and sure enough the same symptoms. This time the SDS remained on for several hours and the voice command mic remained off, though when the voice command steering wheel button was pushed, the 'ring' prompt would sound as normal, and after some time of it not receiving a command, despite my speaking in the normal ok voice, it would say 'pardon'.... and go to the Nav voice commands screen and remain unresponsive.
I reset the Nav system, and no change, though that did erase my address book settings and home setting. I later shut the car down and restarted it and everything went back to working.
No other fuses were touched.
Any ideas about this?
