It is a common belief that an CAI will free up power gains, which clearly is not the case. Coming from a 2010 STI I learned that any power mod will require a proper tune / ECU re-flash.
In order to get the most gains from a CAI, you must re-scale your Mass Air Flow sensor. Your MAF sensor directly controls your fueling in open loop, so a CAI will make your car run very lean therefore you car will not produce sufficient power. If a CEL (check engine light) is triggered which very well possibly can happen, the car will inadvertently run in limp mode which just dumps fuel and will run extremely shitty. My best advise is not to mess with it until a proper module is built to piggyback on the ECU (very much like the COBB ACCESS PORT) or open source tuning capabilities with a laptop computer.
Hopefully someone down the line will be able to break the code.
I will be standing by until then...
