Radio/navigation system not working
Fredshaulage
The radio and navigation system stopped working in my 2013 Genesis Coupe.
At first it was intermittent, now it wont come on. Checked fuse and it tests ok.
david20110
1G Genesis Coupe (2009-2016)
Same issue, mine also turns off randomly at night and turns back on in like 5 hours. I am thinking that it is either a wire that is not making a good connection or that the nav unit is busted.
cgalloway
Phila.Pa.
Radio not working and my Nav. System works on a few things then that's it. Where can I take it to, that will not charge me an arm and leg, in the Philly area?
BigDog65
G-929227
I had similar issue with my 09 Genesis sedan. This morning, when I started the car, the screen was blank, no radio, navigation, or anything on the screen. Saw a thread on the forum that said to put car in accessories mode and pull 2 fuses in driver side panel; 10 amp and 15 amp audio fuses. Turned car off. Reinstalled fuses and it worked. Everything back to normal.
