Radio not working, everything else is
cdfree
Well, I think I have a new variation on an old problem. The AM & FM tuner produces no sound but everything else does: Sirius XM/Bluetooth/NAV/CD--it all works. I don't see any fuse issue. Has anyone seen this before? Thanks in advance. This is for a 2013 Genesis 3.8 with both packages.
Antenna connection? It is different from the XM antenna.
If that happened to my car I'd never know it. I've never used AM/FM in it.
Recently replaced the (original) battery myself and the radio magically started working again. Now, however, I can't open the trunk electronically. Can't pop the trunk from inside the car (hear the noise but it doesn't disengage). Can't open it outside the car with the key fob or manually using the button. Only way is to insert the key. Anyone have any thoughts? When I use the button on the driver door it makes the unlock sound but nothing happens. I've also made sure the glove box trunk lock button is in the proper position. Thanks.
Recently replaced the (original) battery myself and the radio magically started working again. Now, however, I can't open the trunk electronically. Can't pop the trunk from inside the car (hear the noise but it doesn't disengage). Can't open it outside the car with the key fob or manually using the button. Only way is to insert the key. ...
Try this.
Open it with the key and lift the trunk lid to the fully open position.
Press the close switch on the inside of the trunk lid while pressing the open switch on the outside of the trunk lid. Hold both for at least three seconds, till a beeper sounds.
Now close the trunk lid fully by hand.
Press the outside open switch. There should be some beeping and the lid should open fully. Wait till it is done beeping, then close with the inside switch.
Try this.
Thanks very much--worked like a charm! Nothing beeped but the trunk is fully operational.
