Radio shutoff and unlock all doors
raf1919
Chicago Burbs
Hi all, There are 2 annoyances that I'm trying to change but cant find any settings. Want to make sure I didnt over look.. I have 3.3 Elite model.
1. Radio stays on when I shutoff car, until I open door. Is there way for it to just turn off with the car?
2. Unlock all doors. Is there a way to make all doors unlock when I press the button on my handle or fab?
Thanks
Thanks
1- I think there is no setting for this but I could be wrong.
2- There is a setting for this in the dash. You can set the key bob and driver's door handle for open/close all doors with two touches.
1 - I'd have to double check, but I swear there is a way to have it shut off when the car turns off, rather than at door open.
2 - You can set it to unlock all with 1 press on the handle (hardly use the key, so idk about 1 press on that). This setting is accessed through the menus between the speedo and RPM tach. I believe it is called "1 press unlock" or something along those lines.
Thx all I'll check again
Car makers tout that as a feature. First time i was is was 20 some years ago test driving a Buick. Got back and could not figure out why it was till playing the radio after taking the key out.
Does not bother me, but I can see where some would not want it.
Once I get to my destination few sec of silence Is nice..
Funny, nobody complains when the audio comes right on when a vehicle is started....
When all else fails, I push the power button to shut off the audio
Yea it's not a deal breaker just was hoping there was way to turn off. I can see why some might like it. The all doors unlocking is the bigger pain so anxious to go check settings again
Didn't see option to unlock all.. Has 2 press unlock but looks like it's on fob only when I press door handle twice doesn't work
Yes, when I press the driver's handle twice the car unlocks all doors. I do it everyday.
From Manual section 3-4
To unlock: 1. Carry the Smart Key. 2. Either press the driver's outside door handle button or press the Door Unlock button (2) on the smart key. 3. The driver's door will unlock. The hazard warning lights will blink two times. Also, the side view mirror will unfold, if 'Convenience ➝ Welcome mirror/light ➝ On door unlock' is selected from the User Settings mode in the cluster LCD display. For more details, refer to "LCD Display" in this chapter. 3-4 If you press the driver's outside door handle button or Door Unlock button on the smart key again within four seconds, then all the doors will unlock.
I'll try again but every time I press twice on handle no luck.. Key fob double press works to unlock all
It's gotta be in pretty quick succession. Like, clic-click! Not click...click.
Yep got it too work seems like you can't be fast or to slow has to be just right. I was double clicking like mouse
In a couple of days you will get used to it. Same with the door handle. Now, with the radio staying on that's another story, I've found myself starting the car when I really wanted to turn it off because the music is still playing and I didn't realize/forgot that I already turned off.
Personally I find the radio staying on is invaluable feature, as it gives me time to transition my conference calls from the car to the phone without interruption, while giving me time to gather my belongings without having to wonder if the other person is still on the other end, or if the call got dropped.
Sorry, I did this a while ago and guided you a bit wrong. Uncheck the 2 press unlock option. Fob and handle should unlock all doors with 1 press. @sstphoenix just got it functioning, so he may be able to remember the exact menu options better
