Zaphod9er
- May 28, 2023
- Genesis Model Year
- 2013
TLDR: limp mode. Towed to dealer. New HPFP bank 2(left side)$1800, problem persists. Requested $2400 for all new injectors. Declined, towed home. New OEM genuine injectors installed by me. Valves cleaned, New plugs, new oil, new fuel. Problems persist.
2013 Genesis 5.0 r-spec 70k miles
We just bought the car 6 months ago and have put 4k miles on it.
Back in May the wife was out getting the kids and the car started misfiring. Motor was shaking. Told her to stop and wait. I have it towed to the dealer. The are the pros after all. They get the car and diagnose the HPFP bank 2(left side). They charged me 1800 for replacement which is fine, $900 part and $180 an hour in labor. But then they ask for $2400 for all new injectors. I decline the service and have it towed home. I'm very good mechanically and I know I can do that service myself. Towed the car home and ordered all genuine Hyundai parts. All 8 injectors, clips, bolts, gaskets, etc. Just as the shop manual requests. While I'm working I notice the valves are a bit dirty as all GDI get. So I clean them as well. New plugs, an oil change, and I even drained the tank checked for sediment and put brand new top tier premium gas back in. Car runs great for 30 seconds then starts to stutter and stall. I let it settle, try again next day, same results. Today I get ahold of a fuel pressure tester adapter and hook it up. It hits 75psi and holds solid while the car runs. Infact it ran for 3 whole minutes before it stuttered. Pressure stayed solid at 75psi. I shut the car off, came back after an hour. Still holding at 75psi. 4 hours later its down to 60. So I'm almost positive that it isn't the feeder pump or the filter. I've done resistance checks on all the coils, primary and secondary. All of them test within spec. Car is throwing 0 codes. None pending. Non stored. Only the original in permanent from the initial missifres. P0300, p0307, p0308,p0030, p0050.
I'm at a loss on where to look next. Trying to not shoot the parts cannon because puts aren't cheap for this car.
I have a picoscope 2204a and leads should I need to use it. I'm just not sure where to start looking. Could it be a bad ground somewhere? A faulty pcm?? The "glitch" just seems so damn random. It's running much better than it was. Just not solved. I sometimes almost seems like a voltage issue. Like a bad ground or loose connection somewhere but no lights flicker or anything. Some of the solenoids will make alot of noises click n clicks under the hood.
Will try to get a video uploaded too.
Thanks for any help anyone can provide.
