Rear drivers window opening all on its own ?
rammy
Driver's side rear window was open when I got up this morning, so I try to close it by starting the vehicle and closing it....no go nothing with either switch works…? So I cover up the window with a garbage back cause did I mention it was raining !. After covering up the window I come back into the house thinking I'll leave it for a bit and see in a while. Go back out two hours later and find the rear window has closed on its own , so remove the plastic garbage bag as I am very puzzled..... I just looked out the window to check on my rear window and it is open again ?! Can anyone help me understand what the heck ???
There are a few potential causes but we have to narrow it down a bit to be sure. Just answer the following questions:
1, Do you live in Nevada near Area 51?
2. Do you live across the street from a nuclear power plant?
3. Is your tin foil had shiny or dull side out?
4. The voices. What do they tell you to do?
5. Do you get an abundance of facial hair when there is a full moon?
Aside from the above, I cannot think of a single reason a window would move in a car that is shut off. Even in the rain I'm not sure what the water can get to in order to complete a circuit.
