Rear lights
EdP
Supporting Member
SUPPORTING MEMBER
7,135
3,536
Parrish, FL
G-659583
Not allowed. If you powered them they would have to still be a reflector when no power is applied.
§ 393.26 Requirements for reflectors.
(a)Mounting.Reflex reflectors shall be mounted at the locations required by § 393.11. In the case of motor vehicles so constructed that requirement for a 381 mm (15-inch) minimum height above the road surface is not practical, the reflectors shall be mounted as close as practicable to the required mounting height range. All permanent reflex reflectors shall be securely mounted on a rigid part of the vehicle
Sorry, I have no idea what you are talking about. I see you are in Florida, perhaps you are quoting a U.S. or state regulation. I am resident neither of Florida or U.S.
Mr. Incredible
SUPPORTING MEMBER
3,003
1,326
Genesis G80 Sport
EdP
Supporting Member
SUPPORTING MEMBER
7,135
3,536
Parrish, FL
RCH04
53
Illinois
No Genesis Yet!
It is a US regulation, may be in other countries. It would be a good idea to put your country in your profile. You'll get better answers. Since most of is are in the US or Canada here we tend to think on a local basis.
This is a very good idea.
bubbaG80Sport
511
279
63
Genesis G80 Sport
Very cool mod!
Q1) The WigWagger has 2 outputs. Did you wire Output 1 to both of the new bumper reflectors and Output 2 to the 3rd brake light?
This way the new reflectors blink together alternating with the 3rd brake light.
Q2) Were you able to mount the new reflectors ..
a) From the outside of the bumper
b) Got to inside of bumper without removing bumper
c) Removed bumper
Q3) Where did you find/splice the wires to the 3rd brake light?
Q4) Is the Wave Wagger programmable (how fast it switches between outputs/blinks)?
Saw a video where person was using a momentary switch/button to change the pulse rate/delay betwixt the WigWagger outputs. It did not show how it was wired.
Mr. Incredible
SUPPORTING MEMBER
3,003
1,326
Genesis G80 Sport
Pedal Commander
