Rear tire problems
Rms45!
I changed rear tires from nitto motivo to yokahama advan sport . Now car pulls to left under acceleration. Had alignment done and still doing it. Any ideas why this is happening?
tire pressure off? did you swap out the fronts as well
Have alignment redone. Something wrong.
RWD? I have the same (new) pull on '22 3.3 RWD, but I swapped out 19" OEM wheels/tires with 18" winter wheels/tires. Assuming you kept same size as originals, perhaps the different tread in front/back was enough difference from OEM to make it pull.
