If you do a search for remote start you will find a lot of information.Looking for a remote start kit or abilities to tap into existing factory remote start.
Thanks pretty much all I get there is Bluelink problemsIf you do a search for remote start you will find a lot of information.
Search results for query: remote start
genesisowners.com
This helps narrow it downThanks pretty much all I get there is Bluelink problems
I installed "mykeypremium" on 2015 Genesis 3.8 sedan works great. Was made specifically for the car. The range is about 500 feet. You just push lock button twice to activate. It also comes with an autolock feature when you walk away from car that can be turned off/on. Becareful with that because you can lock your key in the car with the auto lock turned on. The remote start works by plugging in new modules no cutting of wires required. Just plug it in with some twisting of your arms, shoulders and body under the dash required. Did you get starter recall done? Any problems. Let me know if mykeypremium works post recall repair. I don't think there should be conflict.Looking for a remote start kit or abilities to tap into existing factory remote start.
I installed "mykeypremium" on 2015 Genesis 3.8 sedan works great. Was made specifically for the car. The range is about 500 feet. You just push lock button twice to activate. It also comes with an autolock feature when you walk away from car that can be turned off/on. Becareful with that because you can lock your key in the car with the` auto lock turned on. The remote start works by plugging in new modules no cutting of wires required. Just plug it in with some twisting of your arms, shoulders and body under the dash required. Did you get starter recall done? Any problems. Let me know if mykeypremium works post recall repair. I don't think there should be conflict.
