Released Electronically Controlled Suspension Module Mando ECS10
RPMTRADE
What is the Mando ECS10 Tuning Module?
The damping force that only 60% of the original suspension can use
Set in the style of owner up to 100%
Even on uneven roads
Automatically detects the damping pressure and actively
This is how it works in a controlled way​
Electronically Controlled Suspension Module Mando ECS10 For 2019+ Genesis G70 | eBay
If you want to advertise here you can become a vendor and pay your way. It would add some legitimacy to what you are selling.
This seems like an interesting device. So if I understand this correctly it's allowing you to set how soft or firm you want the suspension, even beyond what is normally available as far as firmness levels.
It appears you use an app to set the suspension settings to desired levels:
I suspect I had a computer malfunction once in my G70 Sport, as I had the drive selector set to comfort mode, but the suspension was extremely stiff, I found that the car was going over impacts much harder than usual, even stiffer than the sport setting. I can't say I'd exactly want to set the suspension stiffer than it already is in sport as I won't even track the car, but kind of cool that this sort of product is available.
[/URL]
All I know is that I want that app to be called Mando Commando.
I'm confused, how does this make the G70's without ECS suddenly have ECS? Or am I misinformed/stupid?
Pretty sure this only applies to the sport models with ECS. Mine with the standard suspension for example would not work with this item
Dang.... That's impressive!
