Replace side mirror turn signal repeater
Ranuve
Mine is broken so I bought the new piece but I cant figure out how to get the old one out of the housing. Any ideas? Even my dealer is stumped.
I just did mine. Pulled the mirror off with a plastic flat bar. Disconnect wires from mirror carefully and place aside. Removed all screws ...however do not remove the 2 far left silver colour screws ( made a mistake and I did and one screw is now not right)...remove short black ones only, then loosen Silver screw from center of motor...pull off slowly
Then used screwdriver inside house to creat a gap on the outside, inserted old credit card and pried off black facevaround mirror. Then the lower part of the housing also comes off. Upper housing did not come off.wiggled the led strip out with a bit of flexing...and removed wires. Had to flex upper housing without breaking and wiggled led after reconnecting the wire. Then put everything back in reverse.
There was a YouTube video I used...google avante and led mirror
