Resetting the low battery in key message /warning after battery replacement
coyote8400
Recently replace the battery in a key fob for a genesis 2015 sedan. The key fob now works perfectly but the warning message on the dash continues. Is there a procedure to reset all device warnings to factory settings?
Wrong forum - this is for 2009-2014.
But you also need to replace the battery in your other fob... that's where the warning is coming from if you already replaced 1 with a for-sure fresh battery.
This happened to me as well. Replaced the fob battery and the alarm still came up. It stopped after about about 2 to 3 weeks after replacing the battery. I didn't do anything, it just went away. So maybe wait for a while and see what happens.
