Resolution to flutter at 25-30 mph
Yes, agreed. I thought it was the hard rubber that was getting cold and not flexible, causing the vibration. Once it warmed up, the rubber reshaped itself.
Someone once stated at that when you turn the car off and it's warm, the weight of the drive shaft will pull the rubber down and it will harden into that shape.
Could make sense thinking back on circumstances. There is a margin of how bad the vibration is even with the same ambient temperature and timespan the car sits. Occasionally when the car sits for 9 hours at work and it’s the same temperature outside when I go home the vibration is worse (exaggerative term it’s still a smaller margin) than other days. Wonder if it could be because if the rubber does warp sometimes it’s in a slightly more off shape than other times. I also park my car on quite an inclined slope at work and the vibration doesn't seem as worse compared to when it’s parked on a flat surface, again small margin difference. Just thinking about if what you are saying has any truth to it the slope would cause the driveshaft to pull differently on the rubber when it cools. Maybe over thinking but came to mind.
