right turn bulb
lilrobo
lexington ky
No Genesis Yet!
well my right bulb is out again i changed it once and all was good for a while , now its out so i went out to change it again and this time the new bulb didnt fix it , i checked for power inside the socket , none . what else can i do before going to dealer ? i do have the wrapp warranty dont know if its covered , i had a booster hose that wasnt covered
let me know what else i can do
thanks
thanks
Just wondering, whose warranty is it?
Total Warranty Services
Thanks. Just wondering what wrap company wouldn’t cover a booster hose. Doesn’t sound like normal wear and tear, even for a 2015. Just a cautionary tale.
just found out that the light socket is 25 bucks my deductible is 100 bucks , now what to do ?
i do believe autozone (any autopart store) does stock different bulb sockets i would check there 1st splice that into your old one and you are good to go. Also did you try to scrape the bottom of the old socket maybe its not making a connection. Run the 1157 bulbs theyll burn out alot less
i went out and took it apart and after checking all the connections its working now , i kinda hate that now i dont know whats wrong
clean up the connections in the socket, put in a new bulb. Should be good to go for a while (life span varies). If the socket is fried, replace the socket.
thats what i did
