Rigid Collars Thoughts
I may not buy the ridge collars, but I will consider the rear diff performance bushings from the company.
2015-2016 Genesis Sedan Differential Bushing Kit
Correction: I may buy the ridge collar as well if the installation is easy to do on the 2015 Genesis. It seems that many unibody cars have a lot slop in the subframe bolts areas. These may help the car handle much better buy eliminating the extra movement of the stock chassis at those mounting areas. This video educated me on these collars
I think I’m going to get a set of collars and bushings, see if I can tighten up the car a bit.
Side roll on expressway on and off ramps are where you will notice the improvement the most. Again it's not a huge improvement but it hugs tighter with less roll and levels out faster with these installed.
