thompithak3182
ok... here is my question. is there a way to use the rotrex supercharger for the coupe on the sedan? 450 hp out of the v6... does that sound good or no?
As long as the ECU is cracked, i would imagine anything is possible. Uncertain as to whether you would need to change internals, or if the stock tranny and clutch could handle the added power. I would reach out to companies like BTR to see.
Now for the 3.8 GDI and FI, it's been done and successfully without changing the compression ratio. TurboKits has a single turbo kit out for the Coupe making some pretty impressive numbers (And it's cheaper than the non-GDI kit because fueling on the GDI is more than sufficient for moderate FI boost).
So they're running a turbo on the stock ECU?
