Sedond Generation - Jukebox play sequence
veesix
Is there a way to make the Jukebox [2016 Ultimate AWD] play all of the files in a folder, then move on to the next folder and play all of the files in it, etc.?
I can get it to play the files in a folder, in order, but only if it keeps playing that folder endlessly. Shuffle is not an option, since each folder contains files that are for the movements of a symphony. Naturally, I want to hear the first movement, followed by the other movements in correct order.
As I recall, my 2013 did this without any special effort. The 2016 seems to offer only shuffle and repeat. Neither are a good choice.
My 15 Ultimate does this. Plays each folder's contents in order, then moves on to the next folder.
It is possible that I am doing something wrong when I select the play mode. Unfortunately, I couldn't find an answer in the owner's manual. I will have to do some more experimenting with the play list.
I did notice that if I go to the last track in the folder and hit "next" while it is playing - it then goes back to the first track in that folder. However - if I let the song complete, it then goes to the first track in the next folder.
That is strange. I think the Jukebox and USB work the same. I will try to test it further by using a USB. It is strange that there is no discussion of how this works in the manual.
I have this same issue with my 2015 Ultimate 3.8. It loops the songs in a folder over and over with no option to move to next folder. As I have many folders with only a few songs in each, it renders the jukebox mostly useless to me.
Is there any good reason(s) to put tunes in the Jukebox vs. using a removable USB thumbdrive?
