lotikok
- Sep 12, 2022
- Genesis Model Year
- 2023
- Genesis GV60
Greetings, fellow GV60 owners! I'm reaching out from Australia to inquire if any of you have experienced issues with 350KW fast charger (I used Evie 350KW charger). My 2023 GV60 Advanced model appears to be disconnecting from the charger within seconds of initiating the charging process. I initially thought the charger might be at fault, but after speaking with Evie support and trying another charger, the issue persisted. Interestingly, a BYD Seal and a BMW iX successfully charged using the same units after I left the charging space.
Genesis assessed my car and found no issues. I was then booked to a Hyundai dealership, but my vehicle couldn't be tested since they don't have a 350KW charger available. In addition, they did not bother to check if anything was wrong. I've had no problems using the 75KW Evie Charger, which has left me wondering if any other GV60 owners have had success with the 350KW version.
I would greatly appreciate your feedback and experiences regarding this matter. Your insights could potentially help identify the root cause of the problem and find a suitable solution. Thank you in advance for your valuable input!
